alternator problems on 94 impreza
David Ryeburn
High quality marinade (Teriyaki and garlic perhaps)
1 inch cubes of tender meat, preferably from the nursery
Onions
bell peppers
Wooden or metal skewers
Marinate the meat overnight.
Get the grill good and hot while placing meat, vegetables, and
fruit such as pineapples or cherries on the skewers.
Don?t be afraid to use a variety of meats.
Grill to medium rare,
serve with garlic cous-cous and sautéed asparagus.
Coffee and sherbet for desert then walnuts, cheese, and port.
Cigars for the gentlemen (and ladies if they so desire)!
Crock-Pot Crack Baby
When the quivering, hopelessly addicted crack baby succumbs to death,
get him immediately butchered and into the crock-pot, so that any
remaining toxins will not be fatal. But don?t cook it too long,
because like Blowfish, there is a perfect medium between the poisonous
and the stimulating. Though it may not have the same effect on your
guests, a whole chicken cooked in this fashion is also mighty tasty.
1 newborn - cocaine addicted, freshly expired, cleaned and butchered
Carrots
onions
leeks
celery
bell pepper
potatoes
Salt
pepper
garlic, etc
4 cups water
Cut the meat into natural pieces and brown very well in olive oil,
remove, then brown half of the onions, the bell pepper, and celery.
When brown, mix everything into the crock-pot, and in 6 to 8 hours you
have turned a hopeless tragedy into a heartwarming meal!
George?s Bloody Mary
Don?t shy away from this one, it is simply a cocktail variation of
good old Blood Stew. When a pig is killed, its throat is slit and
those present quaff a cup of hot blood to soften the wintry air.
From the dawn of man to this day, humans have always drunk blood!
American deer hunters are a prime example.
1 pint
hi, recently i had problems starting my car, so after gettign the battery
checked (no good) i replaced it. Anyways, the new battery died overnight,
so i started testing things. Whn the car is off, 1 Amp of current is being
drawn, when i disconnect the alternator, no more curent is drawn. The
alternator is reading a resistance of 1500-2000 ohms. this does not quite
jive with ohms law, but i know for a fact that its teh alternator drawing
the current.
So what i need to know is if the battery is connected via relay to the
alternator, and that the relay is stuck on, or if the alternator is busted.
thanks in advance, alex
the current.
I suspect that one or more of the diodes in the alternator has failed.
If a diode's back resistance is low, too much current can flow backwards
through it. Ideally no current at all can flow backwards through it --
that's what diodes are supposed to do.
Your resistance measurement, probably with a hand-held multimeter, is
meaningless. You have measured the effective resistance at whatever
voltage is supplied by the multimeter power source, probably 1.5 or 3
volts. You battery supplies in excess of 12 volts. Effective back
resistance of a diode isn't voltage-independent. If the thing is drawing
1 ampere from a 12 volt source and if your multimeter had a 12 volt
internal supply for its ohmmeter function, it would have read
approximately 12 ohms and not 1500-2000 ohms when polarized one way (and
probably something much lower polarized the other way).
You probably need a new alternator.
David, whose 1997 Legacy Outback had a catastrophic diode failure that
took out one battery 2000 km away from home in California just after the
100,000 km warranty expiry point; to give them credit, two years later
Subaru Canada finally admitted that the 1997 Outbacks had alternator
problems, as Subaru USA had admitted a year or so earlier, and paid for
the expensive third-party alternator (but not the battery)
about the size of a baby?s fist
(there should be one lying around for reference).
Bake at 400°for about 25 minutes -
or you could fry them in olive oil.
Place the meatballs in the tomato gravy, and simmer for several hours.
Serve on spaghetti.
Accompany with green salad, garlic bread and red wine.
Newborn Parmesan
This classic Sicilian cuisine can easily be turned into Eggplant Parmesan
If you are planning a vegetarian meal. Or you could just as well use veal -
after all, you have to be careful - Sicilians are touchy about their young
family members...
6 newborn or veal cutlets
Tomato gravy (see index)
4 cups mozzarella, 1cup parmesan, 1cup romano
Seasoned bread crumbs mixed with
parmesan
romano
salt
pepper
oregano
garlic powder
chopped parsley
Flour
eggwash (eggs and milk)
Peanut oil for frying.
Pound the cutlets.
Dredge in flour, eggs, then the bread crumb mixture.
Fry till golden brown in 350° peanut oil.
In a baking pan, place a layer of gravy,
then one of meat, gravy, and cheese.
Another layer each of meat, grav
