Adventure changing my spark plugs on a 2001 Legacy L.
R
Ron
I just finished changing my plugs on my 4-cyl. 2001 Legacy L. I had an
annoying problem that I never saw on the internet. I tried to read all
I could find on the internet, to be prepared, but something new always
seems to happen.
I found that the spark plug socket attachment for my extension wrench
kept staying behind in the cylinder, every time I finished tightening
a new plug. That was because the piece of rubber that holds the plug
was stronger than the connection between the spark plug attachment and
the 6 in. extension of my 3/8" wrench.
I went to Sears and they recommended getting a locking extension bar.
I bought one, but when I got home, I found out that it did not lock on
to my spark plug socket, so I had the same problem. I had to go back
to Sears and get their brand of spark plug socket, which did lock on
to the locking extension bar.
Then, the job finally was very easy to finish. I wonder if locking
socket pieces are used by most people, or if my sockets were just much
looser than average.
Maybe this can save someone a headache. Solving the loose socket
problem was about 5 times harder than actually changing the plugs.
Ron
seems to happen.
Ron
Could you have removed or 'compromised' the rubber in the socket? Did
you need the plug to be retained by the rubber?
I actually had an old one with the rubber out, but I wanted it in
since the spark plug cylinder is a downwards incline and I thought
that I could more easily start the thread with it held by the rubber.
Without the rubber, I thought the plug might just fall down towards
the thread, possibly causing damage and making it a lot harder to
start screwing it in.
The best solution turned out to be using the rubber together with a
locking extension. It just took me a while to find out.
In the old days (dating back to my 1969 Slant Six Plymouth), there was
no long tube and you could just pull the spark plug socket off with
any pair of pliers. This is my first spark plug change with a long
cylinder.
Ron
cylinder.
Ron
All my plug-sockets have the rubber pulled out (less likely to break a
plug), and I start the plugs into the threads with a piece of fuel-
line over the end of the plug. A longer piece of fuel line can even be
used as a curveable hand-driver.
Dave
seems to happen.
Ron
When installing down into a deep head I often use the end of the spark plug
boot and turn in by hand. I just need it to thread a little and then use
the socket to tighten to torque.
On the H4 since its a horizontal installation I just use the socket without
the rubber insert. I also found that a T-plug wrench will work well as the
rubber will stay in the socket.
:> :>I just finished changing my plugs on my 4-cyl. 2001 Legacy L. I had an
:> annoying problem that I never saw on the internet. I tried to read all
:> I could find on the internet, to be prepared, but something new always
:> seems to happen.
:> I found that the spark plug socket attachment for my extension wrench
:> kept staying behind in the cylinder, every time I finished tightening
:> a new plug. That was because the piece of rubber that holds the plug
:> was stronger than the connection between the spark plug attachment and
:> the 6 in. extension of my 3/8" wrench.
:> I went to Sears and they recommended getting a locking extension bar.
:> I bought one, but when I got home, I found out that it did not lock on
:> to my spark plug socket, so I had the same problem. I had to go back
:> to Sears and get their brand of spark plug socket, which did lock on
:> to the locking extension bar.
:> Then, the job finally was very easy to finish. I wonder if locking
:> socket pieces are used by most people, or if my sockets were just much
:> looser than average.
:> Maybe this can save someone a headache. Solving the loose socket
:> problem was about 5 times harder than actually changing the plugs.
:> Ron
When I changed the plugs in my 2003 Outback, I just used masking tape
to secure the plug socket to the extension. This was strong enough to
keep the socket from staying in with the plug.
I usually use a magnetic extension pick-up tool to carefully lower the
plug into the cylinder until it hits bottom, then use a flat blade
screwdriver to push it off the end and align it in the clyinder enough
to get a socket on it. Then once I slide the socket over it, I turn it
counter clockwise until it seems that it has lined up, then I turn it
clockwise to screw it in. I only started using the magnetic tool
because it is the easiest way to get the plugs OUT without a special
socket, then I had it there when it was time to put them in.
Dove788
