98 forester radiator , bleeding it.. bleeder valve?
G
glasceus
i have noticed a water sound coming from behind the dash since i bought
this forester, i've asked around on the net and everyone have pretty
much agreed its air in the heater core.
i've been told to bleed the air out of the system by taking off the
radiator cap and starting up the engine, wait for the air to burp then
add more coolant.
problem : when i try this the radiator starts to overflow from open
cap.
question: i've noticed a little plastic screw up the far upper right
side of the radiator. its a flat plastic looking screw with a philips
head. is this the so called "bleeder valve" ? does this have anything
to do with bleeding the air out of the system?
can someone please explain this process. thanks!!!
car: 1998 subaru forester S
My 2000 Forester does not have a bleeder. The way I fill my cooling
system is: Park car on a level area or with the front of the car
slightly up. Remove the radiator cap and top up coolant. Run engine at
a fast idle (book says 2000 rpm) for 5 minutes after the top radiator
hose id HOT (thermostat open). Top up radiator-clean cap and radiator
sealing surface and install cap. Top up reservoir. Recheck reservoir
level after the next few hot/cold cycles. Has worked for me always.
Hi Glasceus!
That's the one. Park -w- the cars nose slightly uphill, and let it
idle with the cap off, the bleeder open, and the heater running. It
will likely puke some coolant as it warms up; no big deal, just don't
let your dog drink it. Once the engine is up to operating temperature
(the fans will start to cycle), add fresh coolant until the bleeder
overflows. Close the bleeder, replace the cap, top off the reservoir
if needed, and you should be good to go.
You think that's a PITA, you should see what I have to go thru to
"bleed" the coolant system on my mid-engined MR2 :p
thanks a lot for the help. i went out today and bought 2 gallons of
premixed 50/50 coolant just in cause the radiator pukes out that much.
i'm gonna attempt the bleed this afternoon when the engine cools off. i
hope this works. thanks a lot. i will post the results later
well i tried it, used about a gallon of coolant, and now the water
sounds are louder. i'm officially concerned
Hi again glasceus!
Hmmmm. Didja get any air out during the procedure; you would have seen
bubbles, maybe large, at the filler neck? Was the heater running?
They can be stubborn, but the procedure I gave you has always worked
for me. Admittedly on Legacys, and Imprezas; haven't had to do my
wifes Forester yet (and now _I'm_ nervous), and the older soobies were
never a problem.
I'd try it again; get the front end UP, perhaps on a set of ramps or
something. Listen for air in the heater lines/core, and keep after it
'til you get it to come out. You might try restricting the lower hose
with a large pliers to see if you can force more flow thru the heater
loop? You might also try (this will be a pain in the butt)
disconnecting the heater hoses and filling the core with a funnel.
I'll ask around (I know a couple very skilled Subaru wrenches), and
see if anyone has anything else to recommend; will be next Tuesday
before I'm able to report back, tho.
My manual (2000 Forester) tells me to run engine at 2000 to 2500 rpm
for 5 minutes to expel air. I do this AFTER the top hose id too hot to
grab.
miachapman
