95 Legacy brake problems
S
SeanC
Hello all-
I've been having strange (possibly unrelated) brake problems on my 95
Legacy and haven't come across anything real similar in this group, so
i thought i'd create a post.
1) Brake proportioning seems off - my rear brakes have always done
almost all the work it seems. I haven't needed to change front pads in
a few years / ~30,000 miles, while the rears wear much quicker. Also
confirmed by the amount of brake dust on wheels!
2) After having a pad rubbing problem on left rear caliper, (very
uneven pad wear / audible rubbing noise) i replaced both rear calipers
and rotors using parts from Autozone last year. This fixed the problem
for a while, until I noticed yesterday that it looks like i now have a
sticky left rear pad/caliper AGAIN! I heard faint high pithced noise
that went away when I touched the brakes, and the wheel and bearing
were very hot to the touch when I pulled over. I found that if I
punched the brake pedal just right while driving it would release the
pad on some trips (wheel was cool to touch after stopping) but not
others. Seems like a sticky piston, but these are NEW calipers! I
should mention that the left rear rotor is slightly warped, but not
outside of specification (.003").
anyone have any ideas? could these problems both stem from a bad
proportioning valve? did I just buy crappy calipers?
Incidentally i called the local Subaru dealer a while ago and he had no
helpful information (not surprising). said that he never heard of
proportioning valves going bad.
Well, that's interesting. My brakes needed replacing and it was the left
rear that had worn down the worst. Then the ABS light kept coming on but
that's another post.
95 Legacy AWD wagon
Donnyboy
