92 Loyale "Check engine" possibilities
B
Bob
I'm considering buying a '92 Loyale in mostly good shape, but the Check
Engine light is always on. Seller says a mechanic checked the fault
code and it was "something that could be ignored, something about
emissions" but didn't remember any details. Assuming this is all true,
(seller is a divinity student, unless he's a compulsive liar) what
emission-related problems would cause the light to go on and just how
trivial could they be?
The car is an hour's drive from me so taking it to a mechanic is a bit
of a pain at this point.
TIA
Bob,
From his description, it could likely be the EGR control solenoid. My 91
Loyale has a fried control solenoid, and it actually runs a little better
without it. I'm going to get it replaced anyhow because it blinds me to any
other problem the check engine light would tell me about. . before I bought
the car, I'd insist on a code reading, but if it's just the EGR solenoid
when you test it, I'd say go ahead and buy the car. According to my mechanic
a replacement solenoid can be obtained from Subaru for $83 (and there's
unfortunately no aftermarket equivalent.)
But like I said - definately insist on a code reading first. He could be
lying about it, or not remember the real reason.
Good luck,
--Decimal Cat
It's most likely a EGR solenoid or a CPC (canister purge control) solenoid.
Quite common to replace. Fairly easy as well.
Chris Dalton
