'91 Justy Won't start
drmojo418
i have a 91 justy that when you try to turn the key nothing happens. when i
go and cross the starter it starts. if you sit there and just keep turning
the key for about 30 minutes then once in about 150 turns the car will
start. but once you shut it off it won't start unless you sit there and
turn the key for another 150 turns. does any one know where the starter
relay is located, or is that even the problem. i really don't want to buy
a chilton manual but will if i have to.
thanks
chad
0) The fact that it starts when you jump the starter is a sign there is
no problem with the starter or starter's solenoid.
1) Listen for a clicking noise when you turn the key.
2) If you hear one coming from under the dash then the starter relay is
receiving current but not making contact.
3) If no click, then it's either the ignition switch that is bad or more
likely, if you have a manual, the clutch pedal starter defeat switch.
4) To check that last possibility, turn the key to «start» and hold it
there but pump the clutch pedal «150 times...».
5) If it suddendly starts, you've found the culprit, it's just a case of
replacing the switch (sits on top of the clutch pedal stem) or, like I
did on my Legacy, soldering the two wires that go to the swith together
to bypass the switch.
6) I have no experience with bad ignition switch contacts.
Good luck,
Gilles, Montreal.
Good luck,
Gilles, Montreal.
1) Sorry for top posting on my previous invoice.
2) About pumping the clutch pedal, the switch makes contacts at the very
bottom of pedal travel, so push the pedal to the floor and let it rise
a couple of inches each time you pump. No need to let it come up competely.
i got it to start. i just went down to the local auto parts store and
picked up a push button for the starter and by passed all the starter
relays.
thanks for all the help.
<(e-mail address removed)
boutautos.com>, (e-mail address removed) says...
it is an automatic
Same as he said, just substitute "neutral safety
switch", and move selector into park or neutral.
Steve
miachapman
