2017 Outback 2.5 - P0420 OBD code
Hello, I am new to forums, so I apologize in advance, for any transgressions I may make. My granddaughter has a 2017 Outback 2.5 Limited. Approximately 135,000 miles. About 2 weeks ago, the ECU tossed a P0420 error. Scanned it and found 3 instances, 1 permanent. We recorded livestream data on both O2 sensors, as well as the STFM and LTFM. Recorded on fully warmed up engine at both idle and 2500 rpm. Values for the downstream O2 sensor were consistently in the .735-.740 range at both rpm levels. STFM readings were consistently within +/- 5, mostly close to 0. LTFM readings were consistently 0 on 12 frames. STFM ranged close to 0 on 12 frames.
I did some research on these readings, and I am given to understand that the fuel trim readings indicate no vacuum leak or exhaust leak, and this points to the downstream O2 sensor. Even though the sensor readings do not indicate it is failing, I learned that even so, it may intermittently throw an error. It also seems that aftermarket sensors are not recommended for Subarus. I ordered a Denso sensor, as I found that Denso supplies Subaru with 'OEM' sensors. So, I felt comfortable using Denso. We replaced the sensor and, after a few drive cycles, the check engine light went out on its own and all codes, including the permanent code were cleared by the ECU. This told me that the ECU considered the problem solved. However, a couple of days later the P0420 code is back, with 1 permanent and two that can be cleared.
May we please have some help? BTW, I will be 80 on my next birthday. So, if I have done anything dumb here, please consider this.
Thanks to all!
That code indicates that the catalytic converter is failing, becoming clogged with hydrocarbons, soot and particulates, so it is probably not the fault of the sensor. It is just doing it's job...it is Reporting that there is a problem.
The more important question is this: why is the cat not cleaning up the exhaust? There is no good answer, but the problem can begin with the EGR system and excess carbon from combustion. This makes the question of mileage more important. How many miles are on the engine? At 135k, that is enough miles to start clogging up the cat.
Has the engine had frequent oil changes? A good muffler shop can check the cat and replace it if necessary.
I know that replacing the cat is more expensive than just changing the downstream O/2 sensor. But that is the most likely conclusion.
BTW, Happy Birthday!
It makes me wonder with the higher oil consumption of newer Subarus whether the cats will have a shorter expected life than previous generations.
Higher oil consumption? Haven't seen that in either of our Subies. 2023 Crosstrek with 35k burns zero oil between 4000 mile changes. Our 2020 Outback XT at 105k miles and it burns zero oil between 3000-3500 mile changes. Was curious if we're just lucky? Come to think of it, my 09 Forester hardly used any even at 150k before we traded it for the XT.
It's well documented that with the advent of low-tension piston rings that later models go through more oil than earlier models, sometimes severely so.
So far so good.... However I also recall reading that the extremely thin 0W oil also contributes to this if it's occurring.
Stho151
