2014 Legacy low beams down both - relay?
Both low beam lights not working. Died at the same time, so probably not the burned bulbs,
I Don't think both bulbs did actually die together. No other obvious electric issues, high beams and DRLs seem fine.
Googled, found this: Headlight-Relay-Main-Fuse-Multi-Purpose-Fuse, Part Number: 82211FC120 is this a culprit, is this common failure?
If you locate that fuse check it for continuity with an ohm meter or check for voltage on both sides with a test light. If it's defective it will fail those tests. If it has power on both sides (with the light switch on) or continuity then keep testing for voltage and grounds at the lights themselves.
Did have a look into the fuse box (under the hood next to the battery) in the morning. That Part is indeed the "Main fuse", and it looked fine and untouched - there are marks on the screws holding it. But the chart on the back side of the cover shows identical relays for Low beams and horn. I did a quick swap of them, didn't change anything. Being really short on time today and this weekend, decided to give up, dropped it at the shop, and they say it's indeed the bulbs...
cormorant
