2014, 2019 Legacy Moonroof leaking
So I owned a 2014 Legacy Limited where the moonroof started leaking. I was in the car wash when I noted water dripping in my car. Now my 2019 Legacy 3.6 is also leaking. I've done quite a bit of research and found this seems to be an issue with Outbacks and Legacys, possibly other models. They tell me the channels are clogged but I don't believe it. In the 2014 they replaced the moonroof. I will be taking my 2019 back a 2nd time for this issue. I love the Subaru vehicle and I especially love the 3.6 I have but these stupid nuisances are starting to get to me. Even if it is a clogged channel I shouldn't have to clear said channel - it shouldn't clog period. Has anyone else experienced the moonroof leaking?
Yes, they all clog on every sunroof in every car. It is a maintenance item. Just blow the drain holes out. Takes 1 minute.
As stated by someone else, it happens. About once a year open the sunroof and clean everything. Carefully pour a cup of water in channel and make sure it drains outside of the car instead of inside. On our 2014 Legacy Sport, the drain is on the forward passenger side. It run along the passenger side A piller and drains on the passenger side just behind the front tire.
2023 Legacy Limited here. I'm having a heck of a time finding the drain holes on my sunroof to do a PM on them. I've used a highpowered flashlight and have looked up several demo's on how to clean them. All he videos are for older models Legacies and the numerous diagrams of the sunroof parts do not clearly show where they are located. Can anyone direct me to a site or have some pics they can share of exactly where they are located?. Thank you.
jackamoroso
