Hi Blank!
Driving along the highway and the car just stops for no known reason. It
happened three times on a long trip recently. Had cruise control turned on
at the time but this might be just a red herring. Can put it into neutral
while still moving and turn the key and it restarts. Have had intermittent
trouble with this vehicle since new--sometimes it just wont start. Grind
and grind away at it and it goes. I think it is some sort of electrical
problem but am just guessing. Any thoughts?
'07 car is (should be, anyway) still under factory warranty. I'd take
it back to the dealership and make it _their_ problem.
On a vehicle this new, the most likely candidate IMO is an
intermittent in the wiring harness.
Start the car, stand on your head so that you can reach up behind the
dash, and start moving wires around. Pay particular attention to the
large bundle(s) that terminate at connectors thru the fire wall. When
you move the bundle that has an intermittent. in all probability the
engine will hiccup, or stall. Spread the wire bundle and start again,
moving individual wires until you find _the one_.
My reasoning is this:
When the wiring harness is assembled, the connector male and female
pins are first crimped onto the prepared wire ends, and then the pins
are inserted into the plastic connector blocks. There is a metal tab
on the pin that locks it into the connector block once it is inserted
far enough.
It sometimes happens that, either because one wire is a tiny bit too
short, or due to sloppy workmanship, one pin doesn't get "locked" into
place. When the connectors are subsequently mated, the loose pin is
pushed back in the block w/o making a secure connection. Normal
vibration and/or temperature cycling can then result in an
intermittent contact.
FWIW, this can be a major PITA to find, but is easy to fix once you
find it; just push the wire/pin in 'til it locks. The wrench at the
dealership _should_ know this, and know how to deal with it. Again,
I'd make it their problem.
Hope this is helpful.
