2002 Outback Sport
MAC
Does anyone know if the "Check Engine Light" itself, would flash an error
code? And if so, what pins in the diagnostic plug should be connected to get
a read out?
The check engine light does not flash a code. Very old vehicles did flash a
code but now there are so many that the microprocessor just stores them.
AutoZone will read them free for you. I think I would not mess with shorting
pins as more expensive problems may be caused, unless of course you have a
very good understanding of what you are doing and willing to risk. eddie
Thank you Eddie. Thinking the check engine light might reveal a fault code,
betrays my age, eh?
If the CEL doesn't flash then it doesn't flash a code. Since the are several
hundred codes I think only some trucks (which do not meet passenger car
emission specs) may flash a code.eddie
The car I just sold was pre OBD-II, and if the CEL was on, there was a test
wire that you would jumper to ground to flash the trouble code on the CEL.
My remaining non-Subaru is OBD-II, but you can read the codes without
a scanner by turning a switch on the ECU, and then the codes flash in sequence
on the CEL. It's too bad if Subaru doesn't provide anything like that
but I was planning to buy an OBD-II scanner eventually anyway.
Stephengbear
