2001 Outback Check Engine Light On
scruffzz
Usenet Archive
Read code and it states a knock sensor issue. The car when accelerating sometime just doesnt respond and seemes very sluggish. After a little while it seems to kick in and i am off an runing. Want to know i anyone has had this experience and if replacing the knock sensor makes sense in this case. I have read other forums where it is not always the knock sensor. Please help!
Could be you are not running fuel with a high enough octane rating or there is enough build-up in the cylinders to raise the compression. Try some Sea Foam in the power brake hose and some premium fuel. TG
The computer has probably defaulted to extremely retarded timing if the knock sensor is out. That is why the car is sluggish.
There was a recall on O2 sensors. You have described a common problem. Contact www.suaru.com with your vin number to see if you may be eligible for a free replacement. ed
i just spent $400 on replacement ox sensors for my '02 legacy wagon. (a great improvement, by the way.) where can i find details on the recall?
........ tom klein
StAugustineSurfer
