2000 Forester OBDII
D&SW
Hello!
I have 2000 Forester with CEL lit. My problem is, the connector I think must
be the OBDII connector, is located under dash to the right of steering
column, does not appear to accept the standard OBDII male connector. The
connectors I see on the readers have a horizontal blade between the rows of
pins. The connector I see under my dash, has no slot for the blade.
Am I looking at the correct connector?
Thanks!
DAW
Hello!
Thanks!
DAW
My 2000 Forester DLC Connector, ( OBDII ) is on the left, below
steering column, and to the right of the pull down coin box. Some may
have a cover over the connector mine did not.
Similar Threads
Subarufun
