1998 Subaru Forester rear scraping noise
T
Tom Cowley
While making a right or left turn I get a scraping noise in the rear wheel
area. I have had it to two garages and they don't know what it is. One
garage said they had another customer with the same problem. I thought it
might be the rear brakes so I changed the pads, checked wheel bearings for
play, check CV joints for play, checked CV boots. There is grease in the
differential. The body is not swaying in any way. Nothing hitting the tires
or drive shafts.
The noise was much worse after the car set idle for two weeks. It then did
it while driving straight and in turns. It cleared up after driving for 25
miles and returned a few days later.
This noise started out only doing it while making a right turn and now it
does it both right and left turns. Naturally it wouldn't do it when I left
it at the Subaru Dealer. This is a 7 month noise and it is getting worse.
Any ideas would be helpful.
Tom
Marc,
Is that a common problem and complaint? If I take it back to the dealer
again how much do you think it will run per wheel?
Tom
Tom-
Since you were searching for ideas, I threw that in from my long,
storied experience with cars. I've only been selling them for 3 months.
Maybe something a mechanic could look for, in case no one had thought
of it.
I remember a scraping noise that ended up being a wheel bearing
problem. Sheridan, Wyoming, circa 1970....but that's a long story;>).
Just a wag but may be something with the emergency brake. The car is old
enough that one or both sides could be worn out.
imprezadriver
