Dear All,
I have a 1996 Subaru Legacy Outback with 100,000 miles that has begun to stall after driving approximately 1 mile or 5 minutes the first time each day. The Check Engine light comes on and may stay on for a while (but it eventually turns itself off) and the engine begins to run very rough (as if on maybe 2 or 3 of the 4 cylinders). If you can shift the automatic transmission into neutral fast enough and step on the gas hard, you may be able to avoid the stall, but its a hit or miss situation. When the stall occurs all batery powered items seem fine (no lights dimming or anything). After it gets its almost daily stall out of the way, it seems to run fine for the rest of the day. There are some days when this does not happen, but its rare especially since it has been below freezing each night and I have been driving in the early part of the day. Would you have any idea what could be causing this?
Thank you,
Thank you,
