soulone_1981
Usenet Archive
- Joined
- Oct 2, 2006
- Messages
- 3
- Reaction score
- 0
I have a 1995 Subaru Impreza 1.8L AWD with 401,000kms, when I am stopped the car idles very low and sort of jerks like it is going to stall (although it never does). It started around the same time as I had the spark plugs and oil changed. Also once it has been running and I turn off the car if it doesn't sit for a while it will not turn on unless I step on the gas pedal while I am starting it. I had the air filter, the fuel filter changed, and the throttle body cleaned out. When the throttle body was cleaned out it stopped the car jerking for a couple of hours, and it starts with no problem now. I thought it was maybe the fuel pump, but my mechanic says that it would have the same problems when it was going not just when it was stopped... Does anyone have any ideas on what I should try next (other than getting a new car)
) Thank you Denise
I also put in a fuel injector cleaner in the car about 2 months before this started and in the last oil change I put in oil stabilizer (Don't know if that is relevent to anything...)
