Desiree Lerum
I have a 1989 Justy with carbureted 1.2L engine manual transmission. It
will start and idle (a bit rough) but will not accelerate past idle.
I got the car for free from a friend and he said it ran well before he did a
tune-up on it which he replaced the spark plugs, rotor, and cap. He said
that's when the trouble started.
My dad checked the timing belt and it's alignment to the crank, the
distributor timing with a timing light, and the compression which was 150.
When he looked in the distributor he found one of the two metal tabs bent
inward and had been hitting on the metal part on the distributor shaft. He
straightened it out, but that didn't help it run past idle. He wants to try
a
different distributor assembly, but I'm not sure I want to spend $300 - $500
on a free car.
Help!
a
on a free car.
Help!
