'09 Legacy - rear wheel bearing questions
Are there ABS vs non-ABS versions of these bearings?
Had to replace the right rear (along with the axle, backing plate and wheel speed sensor) and am getting the ERR 55 - ABS dashboard fault.
Was very careful not to drop or hammer the bearing, and it's an OEM Subaru part (ordered online via the auction site).
Ideas?
Just had the same code,mine was speed sensor open circuit left rear,bought oem wheel hub and speed sensor and abs light and traction control light went out after replacement, 2009 legacy,there was only one oem option for the hub,the
tone ring or encoder ring is built in the hub and not replaceable ,my old wheel hub was rusty and chewing up the sensor,err55 code went away also
MSDS
