05 legacy VSS location
Greetings all! I bought an 05 legacy 5 speed trans to modify and put in my Corvair Looking at the trans, I see the neutral switch, and the reverse switch, but do not see a vehicle speed sensor. Does anyone have any idea where the sensor might be located? My Corvair is all electronic and need a VSS for both my speedo and ECU
Thanks in advance!
Tom
I think it picks up the vehicle speed from the ABS sensors at each wheel. I will have to fabricate a pick up point on the trans to work with my Corvair. I am thinking off the end of the coupler that makes it 2WD would be the place to do it.
Tom
Chris Dalton
