03 H6 Outback stalled - no code???
1 Lucky Texan
On a coupla rare occasions in the past, my wife's Outback has set the
CEL and I've only read misfire codes. She never reported poor running.
The car has fairly low miles - 55K and is fairly well maintained.
purchased new, never wrecked.
Recently, the car stalled after moving about 2 blocks or so from being
parked, then it restarted. No CEL and no codes were stored. No poor
running conditions reported. Only happened once so far, but my wife's
confidence is shaken. This is very disconcerting.
Is there a known issue like this? Some kinda relay dropping out or
something? Had a daughter's 90 Maxima that did this (intermittent
stalling) and it was fixed with a 'motor control relay' IIRC.
thanx for any insight.
1 Lucky Texan
1 Lucky Texan
Not a known failure for H4s or H6s of that vintage.
Stalled while at idle or while on the throttle?
Plugs are due at 60K, misfire code points that way as it has no plug
wires.
Is it the VDC model?
I have an '03 LL Bean with the H6, no VDC.
Dave
wires.
Dave
While some vin decoders call her car an LL Bean it isn't. No VDC..
At least one instance of misfire codes was likely fuel related as it
was after a fill-up. the other I don't recall. maybe a little water
went through? And no poor running conditions reported either.
Did the H6 come with platinum plugs from the factory? I probably do
need to get on that soon.
wires.
Dave
I THINK she said she was approaching or at a light. Certainly not 'at
speed' probably low-ish RPMs. No recently purchased fuel.
I wonder if it could clogged EGR valve? I am having a kind of similar
problem not as bad but will lose power wont cut off but lose power and
I pull over wait a min or two and it is fine. I think mine may be
clogged EGR, I am going ot have it looked at. Look up EGR valve on
Google it will tell you what happens when it is clogged.
1 Lucky Texan
Carl, I haven't seen any "stalling" issues with any Subaru's.
I wouldn't worry about the plugs, as for that should not cause a
stalling issue; But get em changed. Have fun changing them!
If you can repeat the stalling, the dealer may need to put a scan tool
on it and see it- one Forester did have this problem, the tech had to
drive the car home many times until the problem duplicated- it had
something to do with the o2 sensor dropping off briefly; but it hasn't
happened sence.
keep us informed
I'm trying to think of plausible scenarios that would create a stall
without triggering a code. Maybe there was an air bubble in the fuel
line, that just happened to strike at that moment in time? Something
like that probably wouldn't trigger a check engine warning, as the parts
involved (fuel pump) wouldn't really be at fault.
Yousuf Khan
happened sence.
keep us informed
I drove it last night and it is glass smooth. I think I have a tire
that causes a little vibration, and I know I have split boot on a CV
joint - but the powertrain is as good as new (I still have a hard
downshift at highway speeds sometimes when passing - always had that)
yeah, reading about the plug change issue is frightening. I think I'm
gonna try it from underneath when I make my attempt. Can I use the NGK
Iridiums or should I just get platinums? got a part number handy?
        Yousuf Khan
I was surprised there was no code. And it couldn't have been - say - a
bad battery cable cause the station presets were still in the radio.
(besides, the engine was running so I guess the alternator should have
putting out) Seems like I HAVE heard of folks with similar year model
soobs having some odd issues when, say, backing the car out of a
garage, turning it off, and then getting back in and restarting with
rough-running and/or fuel smells. (at least, that's close to what I
recall reading about???) Given that my wife was taking her handicapped
friend to a doctor's appointment, I dunno the exact sequence she may
have dropped someone off, parked, started the car, pulled up to a
door, gotten in/out, if engine was stopped/started multiple times in
quick succession or anything. perhaps it was a one-off event. I hope
so.
so.- Hide quoted text -
- Show quoted text -
I have a '02 3.0 VDC. Not sure about the OP issue, but I can vouch for
replacing the sparkplugs. I replaced mine at 65,000. The front 4 were
not bad. The driver side rear plug was somewhat difficult. The
passenger side read plug was a bi*tch. It took me two hours. Now I'm
sure with the right tool it would have been easier. I was using a
standard sparkplug socket/socket wrench. I'm at 130,000 now, so time
to replace again. I'm not look forward to fighting with the right-rear
one again, but I've done it once, so will do it again.
John
John
I gave up trying to get to the rear plugs in my 2.5 after about 3 hours
of trying to figure it out. Just went to the dealer and let them handle it.
Yousuf Khan
so.
I quizzed her some more and she said it died AFTER she was completely
stopped at a light. So, it stalled at idle in gear. From the rest of
the account, it seems the car had been parked for some time - 90
minutes +/- but was started, driven to a different lot, idled for 15
plus minutes, moved to a doorway, placed in park idling while waiting
for X minutes to pickup a passenger - bottom line, sounds like it had
to be at normal operating temp, not cold. I'm quite certain the a/c
would have been on if that matters - it's on a lot here this time of
year! lol!
anyway - I drove it again yesterday, Glass smooth running/idling ( a
slight steering wheel wobble when I release the wheel while moving,
from a bad tire I think) I will be driving it out of town next
Wednesday on a 'road trip' with relatives so - hope i don't have to
tow it home!
LL beans have LL bean badges and LL Bean imprinted on the seats.
Beaners did not have VDC.
Platinum plugs are standard.
Dave
year!  lol!
tow it home!
The car drove like a dream yesterday on a road trip. No detectable
rough-running or missing.
miachapman
