Window glass not moving with motor
S
strchild
'93 Subaru Impreza AWD L Sedan
Okay, new problem to me. (-; Driver's side electric window will not go up
or down unless I move it by hand. Hand movement of the window seems smooth.
You can hear the window motor running perfectly fine, in both directions,
when operated by the switch. Anybody know what this could be before I tear
into the door, so I have a direction to hunt? Is it possible to swap in
wrecking yard parts from the Legacy line, as we rarely get Imprezas in yards
here?
There have been no symptoms whatsoever, prior to complete failure, and I'm
the only user of the vehicle, so I question whether something like this
could be caused by somebody forcing the window down by hand, then back
p? )-; Are there any nylon gears that could strip?
Thanks in advance to all for any help.
~Brian
go up or down unless I move it by hand. Hand movement of the window
seems smooth. You can hear the window motor running perfectly fine, in
both directions, when operated by the switch. Anybody know what this
could be before I tear into the door, so I have a direction to hunt?
Is it possible to swap in wrecking yard parts from the Legacy line, as
we rarely get Imprezas in yards here?
I'm the only user of the vehicle, so I question whether something like
this could be caused by somebody forcing the window down by hand, then
back p? )-; Are there any nylon gears that could strip?
~Brian
Window glass came out of the rail or bracket that holds it. So the
mechanical is going up and down but not with the glass attached. Or an
arm broke off (haven't been inside the door for a year so don't remember
if there is moon clip and/or bolt to attach the pieces together.
Thanks for the tip-off Vanguard, . .
Just went out and checked, since you made it sound so easy, and
unfortunately it's not so easy as just putting the glass back on a
rack. )-; Looks as though the problem is in the "gear box" the motor is
attatched to. Is there a worm gear coming off of the motor shaft that could
have become defective? When moving the window by hand, and watching the
mechanics, everything is functioning, right down to the gear in the gear-box
that is working against the geared swing-arm portion on the scissor
mechanism. I don't suppose anybody has any diagrams, or links to something
that may generalize the mechanics of this sort of mechanism, so I can get a
better grasp what I'm doing? I know there is a spring for the window
mechanism in the door somewhere, and the last thing I would enjoy is a big
nasty spring going up my forearm.
~Brian
~Brian
I have no experience with soob windows, but usually the motor (if
still working) can be moved over to the new 'regulator' (the scisor
mechanism). You might price one from Jamie at www.subarugebuineparts.com
or other online dealer. Email her and maybe she has a drawing she could
attach to email and send back.
I had the same problem with my 03 forester. Brought it in to the
dealer, my mistake.
They told me the motor was stripped internally. 400 dollars later, new
motor and it works again.
I took it apart too, and I was surprised to see that it was in the
track properly.
I think I would have found a new motor from a junk yard, and replaced
it myself, but the dealer was already going to milk me for a hundred,
since they took it apart to diagnose, and let me pick it up broken as
an alternative.
I asked them to check on the wind noise as well, since they had it
apart, but they conveniently forgot.
Hi Brian!
here?
Sorry to bring bad news, but you are probably looking at replacing the
regulator assembly. Possible that you might be able to simply install
another motor, but in all likelihood you will have to remove the
regulator _anyway_ to do so.
Pretty sure Subaru starts with the regulator, and then builds the door
around it; they are a serious PITA, but doable (just) with regular
hand tools. I will comment that the phillips-head fasteners are
frequently ridiculously tight. If at all possible, use a phillips bit
in a 3/8in impact on these to minimize the risk of stripping out the
head.
Anyway, go here:
<http://chester.uccs.edu/WRX_Manual/> and D/L the Body.pdf file.
Obviously for a newer car, but the mechanism and adjustment procedures
will be largely the same.
Good chance the Legacy regulator is the same as per normal Subaru, but
take yours in to match just to be sure.
Hope this helps. Best of luck.
Thank you all very much so far. I'm getting a bit worried as to the actual
"getting in and doing" it part. But, I have the body portion of the manual
downloading now, and will see myself to the local wrecking yard tomorrow, or
as soon as the rain lets up, and the sun can dry the place long enough to
not look like a drowned rat in coveralls. I really don't want to go to the
dealer for this, as they always quote me things at a price that pretty much
could swallow an entire paycheck if I let it. /-; Not the parts guys'
faults, but that's just the way it is. Not an entire stranger to getting
into my door, as I installed an automatic lock actuator earlier in the year,
but sheesh, they didn't leave much room in the door for, well, anything,
would seem. Any good reason a car door can't be split in two for working
on? There some sort of great benefit to manufacturers, producing them as
they are now? Seems they are hardly meant to be worked on. )-; Hopefully
I can post some follow-up, when I have some progress. (-;
Thank you again, to everyone,
~Brian
Thank you all, again. I had a spot of good weather yesterday, got a
replacement motor and gearbox mechanism from the yard, and did the
replacement work this morning. I followed the instructions as closely as I
could from the link Steve shared, and whadya know, they were almost right
on! (-; Two, maybe three hours work (I didn't watch the clock that
closely), a rubber hammer later, and the replacement part is installed and
working.
Would seem that the slip-clutch-like mechanism in the gearbox assembly that
allows the nylon ring gear to move along with the motor's worm gear after
the window glass has come to a stop had begun to slip too much, and could
not grip with enough force to move the window. I like the design, as it
would seem the nylon gear has very little chance of stripping against the
metal worm gear that is cut into the shaft of the motor. But, like anything
else, the darn slip-able portion of the mechanism seems to have worn out.
No way the worm gear is going to strip or come loose, it's machined right
into the motor shaft, and the nylon gear shouldn't strip either, as it
transfer's the torque by means of a rubber gasket like material that it can
slip against.
As far as the Legacy motor/gearbox being a match for the Impreza, I can't
even tell you the year of Legacy, as the car in the yard was not marked, but
upon inspection of the number stamped on both parts, exact same part number,
so as near a match as I can imagine coming up with. The only difference is
the two lead, wire harness coming from the motor. It's longer on my Impreza
than the Legacy, which a quick reroute of the connector placement was able
to solve.
The screws holding the gear assembly to the rest of the regulator really
were ungodly tight, as suggested they might be, but I was able to loosen
them without the need of an impact driver, which is great, as I don't have
one at my disposal right now...
Don't try and remove the motor from the gear assembly as I learned the hard
way, or you will get the joy of trying to put two very small motor brushes
back where they belong, with two very obnoxious springs, all the while
trying to feed the long motor spindle back into the hole it came from. The
one end of the motor assembly is part of the gearbox mechanism, so you can
not separate the motor from the rest of the assembly in it's entirety.
Before I separated the gear assembly from the regulator scissor arms, I
planted the coiled spring portion snugly in a bench vice, which held it
right in place so I could swap it without having to figure out how to reset
the spring. (-; Otherwise, what I learned at the yard is, the spring pops
out of place rather quickly as soon as the gear assembly is separated.
Always nice to be reminded of how much I appreciate my window by not having
proper use of it for a few days.
~Brian
working.
slip against.
to solve.
~Brian
Had a similar problem on my Legacy. Had to replace the motor and scissor
arm on the rear right side. Got the replacement from a wrecker but never
saw *exactly* how he took it out.
Went home and started the fitting. Couple of hours later and seventeen
new strings of swearword combinations and I gave up.
Went down to one of the local panel shops with a dozen of beer.
Works perfectly now but still don't know how they fit
I share your frustration, as that's how I felt, going into the guts of the
magic power window system, that Chinese puzzle box of arbitrarily difficult
automotive engineering, however after how well the whole deal went
yesterday, I would gladly show you how they fit for a dozen of beer. (-;
I can't take all the credit though. Without the manual pages provided by
Steve, I would have used the big rubber hammer more, my brain less, and
filled in the gaps with colorful adjectives.
~Brian
Hi Brian!
working.
Good job!
Steves theory of expertise:
Doesn't matter how little you know about something, if you know more'n
the guy sitting next to you, you _are_ the expert.
I'm pretty sure you qualify as the resident soobie-glass expert at
this point. You da _man_ :)
On another note, no more wind noise from the mirror gusset area of the
window.
Steve, would you be offended if I offered the link you shared with me, to
the body portion of the manual, to those complaining of wind noise? Or I
could link to one of your posts if you prefer.
~Brian
Hi Brian!
Not at all, that's why I keep 'em there.
<http://chester.uccs.edu/WRX_Manual/> '02 Impreza
<http://chester.uccs.edu/ea81/> '84 EA81 engine
<http://chester.uccs.edu/MR2/> '88 and '89 MR2
<http://chester.uccs.edu/movies/> just for fun. Check out wrc-high.wmv
If anyone has other Subaru service manuals in electronic format, send
'em along and I'll put them up as well.
For the past week, my '98 Impreza Outback Sport will lock all doors
except for the hatchback. Also, when I go to lock the car, the wiper
moves. This happened for a week. Now, the back hatchback will not
lock at all via the car remote and when I try to run the rear wipers,
I hear a click, but the wiper doesn't move.... can anyone help please?
God Bless
When I shut the hatchback rear door, the rear wiper (which was left
on), worked for a brief pass (back-n-forth once), so perhaps the wire
damage is in the hatchback itself???? Responses great appreciated!
You will need to remove the door panel to find out, but I still believe from
what you have said it is where the wires bend between the door and the roof
line.
Once you have the panel off you can check the voltages, and move the door to
find the problem.
Blair
