Urgent how to remove turn signal lamp?
Y
yubbadoo
I need to get the right turn signal lamp out to check the bulb. It has
been into the dealer twice and had the connector replaced and the bulb
(seat) "tweaked", but still it either quits blinking or blinks rapidly.
Something is loose or wrong and I thought I'd take a look at it since
I can't keep going to the dealer to fix/replace bulbs.
I've taken out the screw, but don't know where the plastic piece is
that's preventing me from pulling it forward. I pushed a plastic
retainer piece through the inside of the frame under the hood, but it
must be for some other part so now I'm committed to getting it out and
fixing what I've done.
TIA
Noob :) and lovin' this car
TIA
It would help to post exactly what car you have.
OK, I played with it and popped it out (thankfully didn't break
anything). The bulb flashes rapidly if I insert it one way, but won't
twist into the connector slots. If I put it in the other way, it
doesn't blink. Maybe I'll just go buy a new bulb in case someone put
in the wrong kind?? Any other suggestions?
If anyone still has advice on the safest way to pop that out of the
"retainer" clips, I'd appreciate it. I don't want to scrape paint and
break plastic using a screwdriver all the time.
Thanks again in advance.
The turn signals flashing rapidly indicate a bulb is out someplace or
the bulb is the wrong type. The flasher unit is designed to flash
faster when the current through it drops below normal, to warn you
when there is a bulb out.
Put the hazards on, and check all four corners to see if any other
bulbs are not working. To see if the bulb is the proper type, look at
the one on the other side or check your owners manual if you have it,
the info is in there.
Thanks again for your quick reply....you guys are awesome. My bulb
says 1157A and the manual only says 1157. It also says S2A MO. All
the other lights work, BUT this bulb only blinks correctly when I
insert it one way (which doesn't allow it to twist into the connector -
the hazards blink normally, but the right turn signal still blinks
rapidly). The other way twists into the connector, but nothing lights.
I'm going to call the local parts store to see if they can look up the
bulb.
I REALLY appreciate all the help I've gotten here.
bulb.
The hazards WILL blink normally, I suggested that as a way to check
all the bulbs to see if you have another one out.
I'm not 100% sure if the 1157 and 1157A are interchangeable.
A is for amber. My NAPA parts guy thought maybe a spring was stuck,
but everything "looked" OK. I found the contact cleaner and sprayed
everything down. I think the wiring plug at the connector end was
dirty.
Anyway, problem solved for at least an hour or two.
We're off for a drive in the Rockies.
Thanx
... this bulb only blinks correctly when I
See if the lamp gets a good ground. I've had to bend the metal clip
inside the turn signal socket once because it was barely touching the
lamp and the signal lamp worked intermittently.
florian /FFF/
