Tire damaged on 1 month old Forester
markw10
I got my 06 LL Bean Forester around 1 month ago. Unfortunately I had
my first flat today. The worst part is a nail went into the inner side
wall of the tire and I know from the past often that means the tire is
ruined and can't be plugged. Sure enough after going to a local tire
store I was told that it needs to be replaced. I would get a 2nd
opinion but know it likely needs to be replaced.
My question, the car has Yokohama Geolander G900's. I haven't seen
these sold anywhere and maybe they are only sold directly to Subaru.
The guy today made it clear with the AWD system I have to have the
exact same time and he mentioned a Bridgestone tire. I know often it's
said you have to replace them in pairs but since these have only 2000
miles on it is it necessary? I was hoping it was under warranty but I
see they don't have the road hazzard coverage. Can I just replace the
one tire? Should I go with Yokohama or any specific brand or model of
tire I should get? With such a new car and tires I want something that
is very comparable.
Your dealer can get you the exact tire. You dont have to worry about
the wear from 2000 miles.
is very comparable.
I know folks don't want to hear this but the same thing happened to me
and I got the tire repaired by having a plug and an inside patch
installed. It was fine afterwards. The OEM tires are crap anyway and I
got less than 2 years on the R92s on my OBW.
And it really doesn't matter if
I'm wrong I'm right
Where I belong I'm right
Where I belong.
Lennon & McCartney
I had the same problem on my 2005 Forester. I measured the tread ware at
5000 miles and it was still within the circumference difference of the 1/4"
maximum. I put the Geolandar G900 spare on the ground with the other three
and bought the same size 215/60 HR16 Kumho to go on the spare rim. It is
slightly smaller in diameter than the 26.2" Geolandar G900 so it would be
closer in size to the worn tires if I needed the spare again. At 25,000
miles now the tires all show within 1/32" of tread depth. Tirerack
(www.tirerack.com) still carried the Yokohama Geolandar H/T G900 the last
time I checked their site. I plan on replacing all four at around 35,000
miles as the current rate of tread ware indicates they should be worn out by
then.
Blair
If it were me, and with that kind of mileage, I would change one tire only
with something the exact same size. I think the AWD is affected by uneven
tire size but I don't really know by how much, 2000 miles wear would affect
it.
Staff online
JessDJ
