Timing verification 09 Tribeca H6 - I have FSM but Im slightly confused.
So I did a full top end rebuild with heads rebuilt. I got the FSM and I did what it says.
Says to Have the crank mark at 9-oclock, then make sure all cams are at 12-oclock ( though I think one was out of this when i pulled it off but im a bit foggy as I took my time on the project, whether it moved post chain removal or not idk.
But then after the cams it says, NOTE: crank at 3-oclock. So I moved it there from the pervious .
Long story short, I did my best translation and did as the manual states but the car is not right.
It does not start fast like it should and run obviously rough. So I think since it runs it has to out but not horribly to rip its self apart, Im not happy at following the FSM and nit having it right so If i could just get a confirmation that would help me out before I remove the cover again and go at it.
I included what I see.
Thank you for reading and any help would be fantastic. - David
JessDJ
