G
Graham
Hello all,
Don't know if anyone can help out with this technical question but worth a
try.
The Subaru Fiori maybe called 'Rex' or 'Ace' in other countries, not sure.
Anyway this one in Australia has the 758cc engine.
We have a 1991 Fiori, unbelievably great little trouble free car up until a
few days ago. She just stopped, so we called the NRMA (mobile mechanics) and
the guy said the fuel pump has packed it in. We have a service manual for
it, so I had a look at the drawings and see that the pump gets it's power
from what is called a 'Revolution Sensor' which in turn receives a signal
from the coil. The 'Revolution Sensor' has a circuit board inside which
means it is all quite complicated (computerised so to speak). Tested the
power from the 'Revolution Sensor' and it gets 12 volts ok but no amperage?
Anyway, to make a long story short, I tested the pump with a direct 12 volts
and she works fine. So I tried to find a new or second hand 'Revolution
Sensor'. In NSW there are none in existence. The dealerships say they are no
longer in stock and the wreckers have scrapped all the bodies, whilst
keeping only the 'quick selling' parts. The sensor box is mounted under the
dash above the fuse box (about the size of a small pack of cigarettes).
So my question to you all I guess is, do you know if it's ok to run a
permanent power supply from downstream of the ignition system to the pump,
i.e., the pump would be running flat out whenever the ignition is on,
without any variation in petrol supply from idle to maximum revs? It has a
fuel return
line to the tank so in principal it may work but what worries me, is that
they went to so much trouble designing this 'Revolution Sensor' that I may
be overlooking something.
Thanks in advance everyone for any help or advice,
Graham
try.
fuel return
Graham
