Seat Motor Failing?
Driver side lift motor intermittent. Works briefly first click, less second click, then nothing until I try again several hours later. Might be switch but seems more like dying motor. Thoughts? Repair method?
Wiring schematic with a voltmeter and AMP clamp will test for a defective motor.
Defect in the wiring connections, water intrusion, oxidized connections.
The model year? Trim package?
2019 Limited, 26k miles, no evidence of water or oxidation, connections seem solid and clean. Likely volt/amp test will tell all, if I only had the tester.
Dove788
