Put in a Moder Spare tire in my '25 Crosstrek
A while back, I talked to Modern Spare and I asked them since they don't list the regular gas Crosstrek in the choice list, is there still a way to get something to work for my 2025 Crosstrek Wilderness and they came back with it's the same tire they offer on the new 2026 Crosstrek Hybrid. Since I don't do 'hard' off roading (but still have motor, transmission, differential, and gas tank skid plates due to areas that I really needed those skid plates) I wanted a spare tire just to get me out of situations that if I couldn't fix the 'real tire,' I at least wanted something that could get me out of the area so I could make it to the closest tire shop since a donut spare is not acceptable in such situations in my book.
I didn't want a regular spare to put on the roof or get some rear rack to hold it, again, I wanted something more robust than the donut, still compact, and would 'fit' in the regular spare area to be with me all the time. You can even use Modern Spare for your front, not just the rear like the donut spare.
With some work, but nothing drastic, I did get the Modern Spare to 'fit' good enough for my liking. It's roughly about an inch higher and when I put everything back in, if I didn't know I did it, I wouldn't even notice it.
It required removing some of the plastic at the very back that the spare tire fits under. I only needed a sheet metal cutter to take off around a half inch and then sanded any sharp points smooth that allowed the tire to go as flat as can be. The only other mod I had to do is cut a circle in the foam all the jack and stuff fits in to make the whole thing sit flat with the new tire. To secure the tire in its hole, the regular bolt was no longer long enough so I bought a hex cap screw M8 - 1.25 x 80 that worked great with the concave OEM washer. Since the tire is a bit larger in diameter than the donut, it's the walls of the spare area that prevent the new tire from sitting flat. What a shame, just a slightly bit larger area and the new tire would go down enough to be flat, but I'm not doing what others have done and go cutting that area out. Not worth it.
Some pics....
Spare tires are one of life's great PITA. BMW has flirted with run-flats, and now given up on those. I have a donut in an M340, and it did get me home, once. Half-assed street repairs had taken out a sidewall. (Like most folk, didn't test hop the jack and tools in advance, and did make some changes afterwards, including a rug to kneel on.) I was also reminded of my age, and how long it had been since changing a tire by the side of the road. BMW is now marketing a gizmo that attaches to the wheel while it is still in place, and which will inflate it enough to be driveable...assuming the sidewall isn't gone. Of course, that wouldn't solve robot's problem.
Back to the OP's Crosstrek. Have an Outback Wilderness, and, to my surprise and delight,, it came with a full size/full service spare that matches the other 4. It gets rotated through, giving 20% more tread life, and a spare with the correct tread depth if you do totally trash a tire.
Does the Wilderness Crosstrek allow for a full size spare, or is the well different? Battery space for the hybrid surely complicated things. Robot, I applaud your industry, it's just a shame you couldn't make a 5th standard wheel fit.
Dan
I've read that the Crosstrek is not doable for a full size spare. To get that room requires the next size up, the Forester. So no, the Crosstrek canNOT take a full size spare and if put where the donut was at, it would sit way above the level point, somewhere around 5 inches because the diameter won't allow it to rest flat like the donut. Thing is, I wanted a small SUV option that had a great turning radius and low roof height with a good ground clearance. The Crosstrek for my wants was the only option. I just got back from a long off roading trip and I felt better having a decent spare. Dang, that area just had a lot of rain and so much of it was MUDDY. The Crosstrek did great in X mode. I sure didn't want to get stuck way out there.
I carry knee pads, 2 x 4 sections of wood, inflator, tow straps, saw for cutting fallen trees in the way, shovel, traction boards, sidewall repair kit, screw in tire plugs, clue tire plugs. knee high boots, and more for just in case. Your Outback is very nice. Those things rock. Of course, it all cost more money too. Good that you can rotate your spare into the mix for better tread wear all around.
With so many car makers skipping the spare or not even having one, gave Modern Spare a lot of business.
The Modern Spare is expensive, but by the time I got a roof carrier for the spare (and at 73 years old. I'm NOT lifting tires that stinking high), or got a rear rack for a spare, for my needs, I was thankful the Modern Spare cured my issue, plus, it's lighter. Speaking of which, I can strap my two traction boards together with them over-lapping enough to make a ramp for changing tires so I'm not lifting, but rather just rolling the tire up and down the ramp, cutting the effort in half compared to lifting. Then, when slipping on a tire, I can use the shovel to leverage the tire up on the wheel studs.
Have fun and be safe out there, John
FKColo
