P0171 CANT FIGURE THIS OUT
Replaced:
Af sensor
Mass air flow sensor
Cleaned injectors
Throttle body
All connections
Intake
Did a smoke test
WHAT AM I NOT SEEING ON THIS LIVE DATA?
Mpg went from 30 to 20
P0171
Intake air leaks
Defective front heated oxygen sensor
Under performing fuel injectors
Exhaust gas leaks
Incorrect fuel pressure or fuel flow
Incorrect Mass Air Flow (MAF) values
Incorrect Positive Crankcase Ventilation (PCV) or hose connection
EGR valve leaking or stuck in open position
A MAF (Mass Air Flow) value of 0.01 lb/s is not correct.
Even more difficult is offering NO identification of Year, Make, Model and engine type (Engine code).
