- Joined
- Feb 16, 2022
- Messages
- 8
- Reaction score
- 4
The rear brake rotors have lots of rust and corrosion on the brake pad rotor surface. Most on the outer and inner most edges of the rotor. The car stops normally. It would seem the rears are not working correctly. Other outbacks I have seen have normal looking shiny rotor disks. It would seem if the rear calipers were working properly the rotors would be clean. Fluid is full. Is there a proportioning valve that can shut the rear brake off?
