one 1M miles car - can any subie beat that
alf said:
I don't know what the "record" is but I've seen at least one report of a
Subie being used for rural mail delivery that had over 600k and was
still working every day.
I believe the Guinness book records for a gasoline-engined car still go
to a '66 Volvo back in NY w/ about 1.6mil last time I read about it
(still going) and a Honda (early '90s Accord, IIRC) that was traded in
at 1.2mil. Sounds like this fellow's Saab is breathing down at least one
neck?
You might Google "high mileage Subaru"--there used to be a guy
collecting Subie numbers. Don't know if he's still doing it...
I hope a subaru beats it.Officially.
There are engine designs I can't even believe going as far as a documented
world record.. Inlines of any kind have been a tragedy to me.
The records are documented however. They must be in a perfect environment.
An inline four is a wild stab with balance, air being one of them.
A locale that "likes" thier ridiculous engineering no doubt goes a long
way.
By reality and an "anyplace , anytime" mentality
a balanced four (boxer) should be the prevailing champion all over the
world: "anywhere, anytime".
It is in my airplane. <G>
I'm not impressed by Swedish engineering. My son's Volvo has the oil pan at
the rear of the motor and the filter on the side of the block, directly
below the exhaust manifold and above the axle, where it drips when removed.
Just changing the oil is a PITA. On my Outback, I can reach everything I
need without raising the car at all. The wiring harness routing causes kinks
and fatigue breakage of tail light wiring, and the plastic odometer gear is
famous for breaking off teeth. There are a lot of Volvo 240s with working
speedos and broken odometers.
The old Volvo/Peugeot 6 cylinder had more problems than I could describe,
but was especially renowned for head and block cracking.
Of course, accessible spark plugs are a small compensation, but we do 20 oil
changes for every plug replacement.
I don't know what you've got against inlines. What's "tragic" to one man
may be "magic" to another. Wind up an Offy or some of Honda's racing
engines and tell me again an inline 4's a tragedy!
I'll agree an inline 4 isn't the best balanced of all engine designs,
but there are zillions of 'em out there, often w/ LOTS of miles. That
tells me something (like inherent balance isn't the greatest measure of
longevity?) Of course, balance doesn't hurt: there's a reason so many
big commercial diesels are inline 6s! (And many come w/ warranties in
the neighborhood of 600k miles...) Methinks your problems may go deeper
than engine design.
Should we condemn boxers because so few manufacturers have figured out
how to keep them from leaking a variety of fluids (INCLUDING Subie?)
Nothing's perfect...
Rick said:
than engine design.
Same here. I sold a '82 Toyota pickup with the 22R (2.4L) four with over
250,000 miles that never had the head pulled or the crank dropped. As
for balance, you are definitely correct on that one. It would loosen
alternator bolts. It would shake the screws out that hold the solenoid
onto the starter. It even shook a spark plug loose that scared the holy
living crap out of me when it blew out of the head.
eyrepb
