Long cranking 2005 Legacy 2.5 I
JT
Have a three week old 2.5I Legacy with AT. The last few days the morning
start would take a few seconds on cranking before it would start.
Prior to this it would fire up after a couple of spins.
The local dealer had the car sit for 8 hours, and found no problem, and
computer showed all OK. Next step will be to leave it to sit over night.
Has this problem come up before, and maybe some causes?
morning start would take a few seconds on cranking before it would
start. Prior to this it would fire up after a couple of spins.
and computer showed all OK. Next step will be to leave it to sit over
night. Has this problem come up before, and maybe some causes?
My car is parked in a slope, nose up and I had the same problem. This is
how I solved it: turn on the ignition and wait a few seconds before
cranking the engine. When I do, It'll fire up almost immediately. Why?
Search me but this is one possible explanation: I figure that the few
seconds before trying to launch the engine allow time for the electric
fuel pump to build up the pressure in the fuel line. If you try it, post
back and let me know if it works.
start would take a few seconds on cranking before it would start. Prior
When you get ready to turn the key do you instinctively press down on
the gas pedal? You shouldn't. You have a fuel-injected engine.
What I find is if I turn the key and then let it go almost immediately
it will start right away. If I hold it in the start position for a few
seconds it takes longer to start. Hard to describe actually, but the
quicker I let it go, the faster it starts in general. Not every day, but
most days. There does seem to be a degree to which weather and humidity
affects how quickly it will start. Nothing I can put my finger on, but
some days it just works better.
