Location of Knock Sensor - '97 Outback
V
Victor Roberts
In a previous note I mentioned that I was able to obtain a new knock
sensor from a local dealer for my '97 OBW after my mechanic said the
sensor on my '97 OWB was bad but he could not get one from Subaru for
at least two weeks. I now have to wait a couple of days for that same
mechanic to have time to install the new sensor. If this sensor is
accessible from the top of the engine, I should be able to change it
myself.
I would appreciate any info on the location of the knock sensor and
any hints about problems I may encounter if I change it myself. In
case it matters, the Check Engine light is OFF.
myself.
On the SOHC 2.5 it's located on the top of the crankcase, slightly to the right, and behind the
intake manifold. Not sure if you have the same motor or not. One mounting bolt right down through
the center. -Danny
the center. -Danny
Thanks!
Similar Threads
