Legacy turbo 1994
Y
yazmo
I just buy this car and it’s as start acting strange recently.
this is my first car so i don’t realy know how mecanic work at this
time.
1 day ago i had trouble starting the engine turn the key on nothing
happen not even a single sound.
i have check battery and the battery was fine.
i am thinking it’s may be the starter.
it’s happen few day before and i just remove the key from ignition and
wait retry and car run but last night it toke me like 1 hours before i
could start the engine.
it was on a rainy day’s for 3 day consicutive and i have also notice
that i have water accumulation beside the headlight on the frame
depending where i have park myself. today i just got another rainy day
i start the engine and its start right away but it as like a white
vapor near the exaust and in front of the left side radiator i let the
engine idle for 20 min and its as go off.
also i have observe that more i stay in idle more the rpm get lower
near 600 rpm and start around 1200 rpm its was realy stable when i buy
the vehicule now the needle keep going up and down a little
dont know id this normal or not.
so maybe you guy know a lot more then i and hopefully you guy can help
me sort this out
sensor, coils, water intanke, gasket, camshaft, ecu, bad crank
position sensor, what could cause those kind of trouble???
thx in advance and btw sorry for my bad english i am mostly french
canadian see ya
yazmo
time.
me sort this out
canadian see ya
yazmo
The issue with hard starting in that age car, is likely high voltage
related. Bad spark-plug wires and possibly cracked coil housings.
As an experiment, at night, use a spray mister under the hood. Sometimes
you can pinpoint the area that is bad by making an idling car
miss/stumble by spraying water around the plug wires. Occasionally, you
can SEE sparks/arcing at night!
mine wouldnt start a coupla times so i opend the bonnet up and then it
started. think maybe battery was shorting out on the bonnet
If the battery was shorting to the hood/bonnet, you'd have a dead
battery and burn marks in the paint. This one is beyond improbable.
Chris Dalton
