T
theChas.
My '89 Justy (carbed, manual) has a bad habit of not starting, at times. It
may go months without any problems, and then it won't fire. It always has
fuel, the problem is the ingition. After waiting 10 mintues, it usually
starts fine, but not after 8 mins. My shop had it for 5 weeks and could not
locate the problem. It would not start for them most of the time, so they
had it in the ideal situation to trouble shoot. They changed out and tried
every item in the ignition from the computer to the the firewall items, 1st
oxygen sensor, key switch, to the distributor. They consulted the Suburu
agency in the neighboring city and still could not locate the fault. Most
times it will start after a tow, or coasting downhill. I feel low battery
voltage (while cranking) might be the problem...???? Shop said it was fine.
.. . . Sure would appreciate it if someone knows of such a 'quirk' about
these little cars, and the remedy..thanks in advance.
