How easy is replacing rear anti-roll bar?
Mike Wagenbach
Want to beef up my 2.5RS to 18mm. It looks like this should be
stupid-easy to pull off and swap. Is that true?
The only potential problem would be rusted fasteners. I'm assuming you're swapping in a WRX bar?
If so you'll need the appropriate bushings.
On my '02 Impreza the location of the evap. emissions canister & hoses was interfering with hardware
removal on one side, which made things slightly challenging. It's a lot easier if you have someone
to help you hold the bar in place while you handle the wrench.
