Help, cam seal leak, can't stop
C
Charlie Sachs
Subaru friends, I have a '98 2.2 that has just undergone a timing belt and
shaft seal replacements (3). Originally the crank seal was bad its
replacement is doing fine as is the RH cam seal. My problem started when I
nicked the LH camshaft with a drill bit while trying to pull the old seal.
I removed the seal housing/sensor casting and polished the area so that no
burrs were left to slice the new seal.
I blued the shaft end where the seal rides and did a test fit to see if the
sealing lip was in contact with the drill bit nick/ gouge. The first time I
placed a new seal all the way in to the bore against the bottom face. When
that arrangement leaked I installed another new seal and a new housing O
ring. I pressed this seal in 1/16" deeper than flush but not bottoming as
before. This position also located the sealing lip inboard of the shaft
gouge. I'm thinking at this point: there's room inside the seal for
drainage while the seal is running on a good shaft section. Wrong. It also
leaks- not quite as much but enough to deposit a few drops after a long
drive.
This Legacy has 120K and is not worth the investment of a new shaft The car
can run this way indefinitely as long as the oil stays away from the pipes.
The previous crank seal leak was a smoker. This one drips from the lower
water neck and goes to ground. So I ask the more mechanical of you to offer
any thoughts or ideas.
Thank you, Charlie in Pittsburgh
drive.
What I want to know is how someone as clever as
you could do something as silly as use a drillbit
to try to get a cam seal out. Was the drillbit
in a drill and turning?
Enough for the smartass reply. I would use the
time-honored country mechanic method. Take out
the camshaft, clean it carefully, fill the void
with JB Weld, after it hardens, carefully dress
it with a file and fine sandpaper to restore the
shaft radius and put it back in.
A better fix might be to take the shaft to a
welder and have him fill the void using a tig
welder. Again, you'd have to carefully dress
the weld down to the same radius as the rest
of the shaft.
The tolerance is to critical for JOB weld or welding (unless returned in a
lathe). They make thin chrome sleeves for this propose...sometimes the stock
seal will work, if not a seal with an inner diameter to fit the sleeve is
available. TG
Or better yet take it to a machine shop so you can guarantee the diameter of
the shaft is within design tolerances so the seal will not leak again. I
wouldn't trust myself to get it round enough not to leak. These oil seals
are fussy enough as it is.
KristiKat
