heater core...
C
cale
I have an 86 GL-10, and it hasn't been making heat. I have come to the
conclusion that the heater core is bad, since one hose is hot and the
other is cold. I have called around, and the price to get a new one is
like 600 bucks. Thats about 3/4 of what the car is worth. Heater cores
are very hard to come by for this model. What can i do?? Thanks in
advance.
advance.
If it's clogged you may be able to remove it and take it to a local
radiator shop to be flushed or re-cored.
The lever that controls the heat, hot to cold, works a valve in the hot
water line.
If it doesn't work, it causes the same effect and is more likely your
problem.
Check that first.
water line.
problem.
Check that first.
ok, well i will check on that, but how do i access that valve? thanks
I don't think this model has that valve. The heater core is like a $20
used part at a wrecking yard. Anyone from an 85 to 94 should work. Had
plenty of Subaru radiators good bad over the years but never a heater
core. Check the linkage down by the gas pedal. Make sure everything
moves when the control buttons are pushed. I have seen several Subarus
that had no heat only because a small plastic clip down there was missing.
There must be some valve that's closed. It's not likely that a heater
core would be clogged to the degree that you would have the output
hose be totally cold. Or maybe you have a defective heater control
unit.
