U
Uncle Ben
My 1999 Outback had a sticky latch on the hatch that has bothered me
for years. Fairly frequenty I could not open the hatch normally
without ripping out the upholstery and spraying WD40 blindly onto the
latch mechanism.
Finally even that didn't work. Peering down through narrow access
holes I could see that a spring-loaded sliding part was not sliding
far enough back (against the spring) to unlock the latch.
Figuring that something hidden was broken or worn out, I plunked down
$202 for a new
"hatch latch assembly. I was told that the charge for installation was
another few hundred . But I balked at that.
Turns out that the replacement of that assembly was only an hour's job
-- for the first experience. If I had to do it again, I could do it
in ten minutes.
It is a trick to detach the two long actuator rods, one from the
outside handle and another from the lock mechanism. The first was a
surprise; write me if you need to know how. If you buy the replacement
part, you can see easily how to do it.
You have to detach two connectors; both come out straight along their
long axes, but has a locking mechanism you need to squeeze.
For the rest, it is three bolts out and you can wriggle the old one
out and put the new one in.
But perhaps a new part is not necessary, and knowing what I know now,
I might have saved the $202. The sticking part may need only some
lubrication. You can't get at it without removing the part and
looking at its bottomt, but when you do, you can see how to lubricate
it. Once you know how to pull or replace the part, it is easy.
I paid so you may not have to!
Uncle Ben
latch mechanism.
$202 for a new
in ten minutes.
Uncle Ben
