fuse box on 2001 Outback?
T
t00f
My headlights are out, but the brights seem to work and I am hoping it's a
problem with a fuse but can't locate my user manual or where the fuse box is
located.
Can someone direct me to where to look?
Thanks!
If it's the same as my 04 then there are 2. One is underhood drivers side
the other you have to remove the coin tray by pulling it open then pulling
horizontally off its hinge. A 3rd little used fuse box is facing downward
under the last fuse box.
Under hood.. drivers side. Big box. Unclips from back to front. there are 4
fuses. They should not go unless you have a short. If one goes all your light
go on (hi and lows become middle range)
Some wierd setup there.
miachapman
