Hi Jim!
How do you test a Forester front suspension? My 2001 model has only
45,000 miles but is nearly 10 years on the road now. Ride is rather
stiff. Perhaps somewhat attributable to the cold winter weather.
I'm suspecting that unlike old suspensions that got mushy perhaps these
seize a bit causing a jostling ride?
Extreme cold will certainly stiffen things up until the tires and
struts warm up; probably 10 or 15 minutes of driving.
When these struts go, the ride gets pretty springy. Not mushy,
exactly, but kinda "boingy" and under damped feeling. We have two, a
'99, and an '02. Struts on my '99 were replaced at about 110K, and my
wife's '02 are about due at 140K. Mine sees lots of back country
washboards, the missus pretty much stays on the pavement.
Easiest way to check the struts is to remove the wheel, and look at
the strut body at the top where the shaft enters. If this area is
clean and dry, the strut is OK. If oily/dirty looking, it is starting
to go, if wet with oil, it's history.
These aren't too awfully hard to change out, but you will need to buy
or rent a spring compressor, and while not impossible, I feel that the
job would be much more difficult without an air impact wrench. Also,
you have to open the brake system at each wheel to free the strut from
the brake line. This means a brake bleed, which requires a helper or a
pressure bleeder tool.
I'd recommend that you replace all four (if one is bad, the rest are
probably marginal, at best), and use the KYB's (probably around $250
for the four; try ebay). You will be amazed at the "new" ride. If you
decide to DIY, write back and I'll post a couple tips that will make
things a little easier.
FWIW, there are several aftermarket coilover systems available for the
Forry. These generally stiffen the ride a fair bit, and do allow for a
great deal of adjustability (flip side is 100 different possibilities,
99 of which are incorrect ;-), but they are expensive ($1500 - $2000
or more). Generally, tho, they can be worked on w/o a spring
compressor or impact, are rebuildable, and offer huge "cool" points.
