Forester 1999 air cleaner replace problem
W
Wilco van Diest
Hello,
how can I replace the air cleaner element of my Forester '99 (no turbo) ?
After removing the bolt and the 3 clips of the air cleaner case, I can't
turn this case far enough backwards.
It touches the chassis. There's not enough space left to take out the old
element.
Regards,
Wilco
If it is similar to the 98 model, you need to move the upper case part
backwards and downwards rather than just backwards, then it does not hit the
lip of the bulkhead.
Then you will have JUST about enough room to remove the old and fit the new,
but it is an annoying fiddle for such a basic regular maintenance task
