Follow up to Head Gasket in a bottle repair and a question...? (Ray O et al, listen up!)
H
Hachiroku
The headgasket 'repair' on my '89 Suby GL Coupe seems to be OK. I haven't
had a good look (since it won't stop SNOWING!) but the next day we get
where there's more than 5 minutes of sunshine I have to change the oil, so
I'll take a good look at the area where the coolant was weeping from the
headgasket. Other than that, the car seems to be running nicely.
After doing the 'repair' I noticed a new noise from the car, and a guy
from AutoZone surmized the gasket repai may have gotten into the water
pump bearing and is causing a problem. It was a bearing, alright, but it
was the A/C Idler pully bearing that seized! Of course, in the middle of
the night in East Overshoe. I put up with the smell until the belt wore
down enough to stop cooking, then cut it off the next day. (It's the A/C
belt, and is redundant to the fan and PS pump, but doesn't affect the
alternator.)
So, the question is HOW MUCH DRAG CAN AN IDLER PUT ON AN ENGINE?!?!?!?!
Holy Cow! After I cut the belt off, it was like driving a different car.
The acceleration is back, the car runs great, and the gas mileage went up,
even though I used AWD most of the night last night. Previously I was
getting 26 MPG on a warmer day, no AWD, and 19-21 MPG in the cold with the
AWD on. Last night I got 25 MPG using the AWD almost all night.
alternator.)
Obviously, a lot. If a brake were slowing decreasing the gas mileage
that much, it would be glowing red hot by the time you drove a few
miles. How long did you have a power loss? But I wonder if somehow the
problem caused the sensors to be messed up or something and that caused
the loss of power and poor mileage.
The other thing this type of seizure can cause is the crankshaft to be
pulled out of place (like pulled being pulled up to one side) because of
the extra torque needed. This could damage the bearings. I somehow
remember this ruining a few engines in the old days.
Jeff
If the AC clutch seized then you'd be running AC during winter, right?
That probably won't be very good for the compressor if the refrigerant
couldn't evaporate. Your compressor is going to get liquid slugged.
Otherwise I don't know why the belt would burn unless the compressor
is generating a lot of resistance to turning.
When it is warmer out (say around 10 C or 50 F), the compressor often
comes on when the vent is set to the defog position to help dry the
windshield. This also helps keep the seals moist.
I have never heard of a problem with A/C with getting the refrigerant
slugged.
Jeff
The AC idler pulley was seized, not the AC clutch.
The AC clutch was one of the first things I checked on the car. It seems
to be operating normally: locking when the AC is turned on and
free-wheeling when off. It was the idler bearing that seized and started
burning the belt.
That's not good!
Luckily, not only was the bearing on the way out, but the tensioner also
was stuck at less-than full tension, so the belt was slightly slipping
anyway.
The AC runs often in the winter - every time one uses one's Defrost setting.
It uses the AC to dry out the air.
Tomes
Also assuming things are working correctly (always a risky assumption) The
AC shouldn't have to do much work when the air is already cold and dry.
That is, the load on the engine is significantly less than when the
weather is hot and damp.
-jim
setting. It uses the AC to dry out the air.
Tomes
This car is older than that...
The earliest factory air conditioning systems (circa 1940 Packard)
did not have a compressor clutch, the compressor ran whenever the
engine was running. (To "turn off" the AC during the winter one would
have to remove the compressor drive belt.)
The earliest factory air conditioning systems (circa 1940 Packard) did not
have a compressor clutch, the compressor ran whenever the engine was
running. (To "turn off" the AC during the winter one would have to remove
The car is not *THAT* old... ;)
I had a Rambler that had a 'Desert Only' switch. As near as I could
tell, the idea was to use the A/C to cool the heater core to assist in
engine cooling!
weird
"Hachiroku ...
Older than what? My little brain here is trying to tell me that the old
1971 Pontiac Safari wagon we had did this. When did using AC for defrost
start then?
Tomes
engine cooling!
I don't know what the desert mode did, but that wasn't it. Any heat
removed from the heater core by the a/c would be dumped by the
condenser plus the additional load on the engine from running the
compressor.
Steve B.
engine cooling!
The Weather Eye in my Hornet has the "Desert Only" AC setting. The purpose
is to provide maximum cooling in a high-heat, low-humidity environment
(i.e., the desert). The compressor is run continuously on this setting,
which would lead to evaporator icing if the humidity is high. (Perhaps
the old Packard system did not get cold enough for this to be a problem.)
Dove788
