Flat-No power above 3000rpm
A
aloveridge
I was hoping someone could help with advice.
I've got a 2001 subaru WRX which has just had a power engineering engine
tune - exhaust + remap+etc. Very good...
Unfortunately, somethings just failed - it's now undriveable - it will die
if the throttle is pressed when driving - although it's possible to drive
(managed to get home) with vitually no throttle 3rd gear 3000rpm.
Power engineering are unwilling to send anybody out with a laptop (I am
certainly not going to drive it 100miles to London), and I fear my warranty
is now void.
If anybody recognises the problem I would be very grateful for advice - may
be it's something simple like a loose with on a sensor?.....
Best regards,
Adam.
aloveridge said:
is now void.
Geez, if you hadn't mentioned that you had your beast modded, we'd probably
have a lot of solutions. I was originally going to suggest making sure that
your air filter was replaced properly. My 2000 OBW had a power drop off
because of an improperly mounted air filter once.
But since you had your car modded, I'd definitely get to London if that's
your only solution.
Yousuf Khan
Thanks for your help/advice.
I'm attempting to get it done on the warranty, The guy that came out
suggests it either the mass airflow or lamhda sensors. It needs to go to a
dealer - apparently not many people have the right diagnostic gear.
Unfortunately Subaru have closed a lot of dealerships down and everywhere is
quite busy!
Lucky it happened inside 3 years I guess - Would like to read the error
codes from the ECU myself. Does anyone know how to do it with an
oscilloscope? Mind you I see that you can get ISO OBDII interfaces for
$50... Any advice much appreciated.
Regards,
Adam.
Just to update.
Subaru would not touch it, due to it having a different exhaust and the fact
the codes were showing p0545, p1301,p1544, and two more - the other two were
caused by the truck driver trying to diagnose the problem.
I did some searching and found that the Exhaust temperature sensor could be
at fault and that a 2.2K ohm resistor could cure it. - It did. After 3
journeys the malfunction light dissapeared.
I have since purchased an OBDII reader from the States. I plan to clear the
codes and replace the faulty temperature sensor.
I guess with a decatted up pipe, the sensor life is reduced. - I believe the
sensor must act as warning device as well as an indicator for emission
performance.
Does anybody know how to prolong the life of these sensors?
Regards,
Adam.
Stephengbear
