ECU codes P0420 and P1442
  • Thread starter Andy Leszczynski
  • Start date
A
Andy Leszczynski
My wife's 2002 Impreza 2.5 TS reports codes P0420 and P1442. First one
is about the oxygen sensor - the diagnostic tool shows it works fine -
there must be somre rare condition which triggers that. So I just choose
to ignore it.
However second one: 1442 - I can find what it means. Does anybody know
what it could be?
Thx in advance, Andy
PO420 Catalyst System Efficiency Below Threshold
P1442 Fuel Level Sensor Circuit Range/Perf
Andy,
This is what the chart that I have shows as the cause. Kinda Cryptic, but
maybe a google will help decode this.
Bill
What are the miles on this and has any work been done recently?
http://www.superchips.com/images/installation/ul/install-23.pdf
Lists the P1442 as "EVAP Vacuum Switch Hi Volts during Ignition on". Might
be a loose connection on the switch causing the detection circuit no to load
down and the voltage to read high. Maybe a "Rodent" ate thru the wires, the
connection came loose or there is corrosion in the connection. Good Luck...I
have no idea where to find the switch or if Subaru even has one...
Bill
Andy Leszczynski said:
My wife's 2002 Impreza 2.5 TS reports codes P0420 and P1442. First one is
about the oxygen sensor - the diagnostic tool shows it works fine - there
must be somre rare condition which triggers that. So I just choose to
ignore it.
what it could be?
You must not be an area that has yearly inspections. Won't pass around here
with a light on so ignoring it is not an option.
For what its worth the 420 code is not an O2 sensor code. It is a catalyst
problem code. There is an O2 sensor before the cat and one after the cat.
The reading between the 2 is compared to determine if the cat is functioning
properly. If you determined both O2s are working correct (as you stated)
than it may be getting time for a new cat. Did you reset the code and did it
come back on?
WTF did my reply go? I replied last night and told you exactly what the
error code was.
Txh for all the input. I will reset the computer (by disconnecting the
battery) and observe if it goes off again.
A.
ignore it.
what it could be?
Googling gave this thread on another forum with more details on the P1442
(including what to do about it):
http://www.i-club.com/forums/archive/index.php/t-77637.html
Mike
