Easy way to check gas mileage?
H
houndman
I have about 600miles on the Imp 2.5i 5M and haven't been babying it,
though trying not to rev it too high yet. Started with a full tank and
added some gas here and there and rough figuring it looks like 30mpg,
which I doubt. Though I've put a good bit on on highways, I haven't
driven for economy, and red lights and all 4 way stop streets in the
city, and trying to figure out the best shift points should have made
the mileage really low.
I believe the cars have a low fuel light, so planing on running it
down to light it, and then adding gas and runing it down again.
Figured that would be an easy way to figure how much gas I used.
VF
VF
You write the mileage on your gas ticket, reset the trip OD to zero
throw the ticket in the glove box and every so often, put them in a
spread sheet that has been set up with all the calculators. Then,
over time, you have a good read.
such as:
Subaru Forester
Tank no. miles gals mpg %highway highway miles
city miles
1 263 9.76 26.95 65% 171.0 92.1 AC
2 276.1 11.036 25.02 63% 173.9 102.2 AC
3 271.5 12.168 22.31 0% 0.0 271.5 AC
4 280.7 12.199 23.01 0% 0.0 280.7 AC
5 236.5 10.851 21.80 0% 0.0 236.5 AC
6 222 9.486 23.40 64% 142.1 79.9 AC
7 255.7 11.305 22.62 31% 79.3 176.4 AC
8 530.7 24.486 21.67 0% 0.0 530.7 AC two
tanks
9
10
2336.2 101.291 23.06 566.2 1770.0
24% 76%
Doesn't paste exactly lined up into the news reader, but you get the
picture. BTW, not knocked over by the Forester mileage, particularly
city miles. On the two tanks, missed a reset, no harm done just add
the two tickets together.
Frank
Fill the tank (let the pump shut off automatically. Do not top off.)
Reset Trip Counter to Zero.
Drive.
Fill tank again. Note # of gallons needed to fill tank.
Divide Trip Counter reading by gallons needed to refill tank for your
MPG.
I keep a cheap solar powered calculator in the passenger cabin for
this ritual.
You can also get a meter that plugs into your OBD-II port and will
give you a constant readout of running MPG.
I usually don't fill the tank unless I am going to NJ from PA, where
gas is .40-.50/gal. cheaper, And they pump it, so was looking for
ideas to check smaller fills. Really just want a rough idea, since big
city driving can really cut in to mileage, though the new Sube has be
exploring again. Introducing it (and me again) to some neat roads.))
VF
VF
Drive.
MPG.
this ritual.
VF
With the methods suggested it doesn't matter how large the fill is.
The only thing that needs to be constant is letting the pump self shut
down each time and don't try to push any more in the tank.
Frank
Its not feasible I'm afraid. Without filling the tank, or
establishing some means of knowing a given gas tank level, you have no
fixed measure of how much gas was consumed in the miles driven.
But I have an idea.
If you are interested in knowing your mileage, plan a trip to PA where
you can in good fiscal conscience fill your tank, then, when back in
NJ, affix a small red E to the instrument cluster where the 3/4 of a
tank line is on your fuel gauge, and pretend you're running out of
gas.
This will get you the emotional comfort of smaller fills, and be able
to fill the tank on every fill, so you can resetting the trip odometer
and have a chance of calculating mileage. And you'll never run out
of gas.
Best Regards,
VF
First mileage on my Forester was erratic but high. Found tires were
inflated to 40 lb. which probably helped mileage. Others said this is
common and dealer said they come like this out of factory but they did
not adjust in car prep.
Frank
David; Tell me more about the meter for MPG that's driven by the OBD-11
port.
Thank you, Lyle.
such as:
Subaru Forester
city miles
tanks
9
10
24% 76%
Frank
If the calculator is too cumbersome, you can get a little slide-rule
sort of thing where you line up the miles and gallons, and it shows
you the mileage. I got one as a freebie from my mechanic years ago
that clipped onto the sun visor, and it was a great convenience for
many years until it wore out. The nice thing was that you didn't have
to write things down, since the slider would stay in whatever position
you left it until the next time you gassed up (You still want to take
notes if you're interested in more than a general "Did it get better
or worse since the last time")
But I have an idea.
gas.
of gas.
Best Regards,
wouldn't the low fuel warning light come on at the same point? Read it
won't go out unless you put 4 gal in. That eliminates my 5$ fill, or
even 10$.(( Figure it wouild be pretty accurate, recording how many
gal I put in and calc the miles till the light comes on again, and put
more in asap, or add the miles since the light came on to the next #
of miles, or is that subtract them??)
VF
I guess you could use that technique as a rather rough gauge (when it
comes on does vary by incline IIRC). Would it give you two
significant figures of precision in your mpg measurement? I dunno.
When the tank's full and the nozzle shuts off, it's generally full
with a rather low variation since the filler tube's diameter is such
that you're not dealing with a lot of volume variation between
different fuel nozzles, and the measurement ends up rather precise.
With the low fuel light, you're dealing with a vertical fuel level
measurement amplified over the area of a rather large tank.
But really what's the point? Why not start filling the tank with more
regularity? Averaged, I challenge you to prove that you're saving any
money with these partial fills unless you're actively changing your
destinations based on getting to PA for fill ups with cheaper gas on a
regular basis (and in that case, is the savings nulled out by the fuel
burned to get out there?)
Best Regards,
Frank
You also need to record the amount of fuel put in over at least 3 or 4
fills. And it only needs to be 'full to the brim' at the start and on
the last fill.
Back a few years I competed in some 'economy' events and we found that
some cars had a flat top to the tank and the breather was not at the
highest point of the tank. As a result sometimes there was a bubble of
air trapped in the top of the tank when it was filled at night.The
competitor thought he had had a wonderful day. It evened out over the
next few days. At the end of the event on the final fill we always made
sure the cars were rocked from side to side to burp any trapped air out
of the tank.
Back then (mid 70s) we were getting 44MPG (Imperial gallon) out of a
Corolla.
Best Regards,
I don't drive all that much, and putting in 30$ worth at one time
seems like a lot of money, even 20$'s does.. It's NJ where the gas is
cheaper, and I only go when I have to, and then I will fill up,
because of the price.
I was just trying to figure how to use some features the Sube has, to
check mileage. After breaking the car in and learning all the
controls, and adding all the parts I have bought to put on it, I may
put very few miles on it, since I bought it as a more dependable ride
to some distant places in a state forrest in NJ to go star gazing, and
where relatives live.
VF
VF
Partial fills should be avoided. There was a time when that was the only
way I could drive and my daughter has hit-and-miss funds and does
partial fills. It is common, but really, it increases the amount of
moisture and debris that enters the tank , and there is more evaporative
loss, when the gas cap is off.
But you realize this is all just mental. You're spending the money
eventually anyway. You can go to the gas station just as often and
put just as little gas in as you always do if you start looking at the
3/4 full mark at the Empty line. And you'll be able to figure out
mileage reliably.
mileage reliably.
I had an injury that damaged all systems. Brain damage and I had to do
my Own cognitive therapy, because I couldn't handle the 5 day, 6hr/
schedule, because I couldn't stay awake for more than 3 hrs. I would
get So tired, I would hope I had enough gas to get to a station the
next time I drove, because I coudln't stop on the way home, Getting
home, even a few blocks, was pure agony. I had to relearn, math and
spelling, because if short term memory damage, though long term was
still in tact, so I would practice, and make up games and tests. Had
to figure out the prices and add them up, Before i went shoping, so i
didn't feel like I got overcharged. I couldn't do it on the fly, at
the register. With the price of gas, and Knowing the oil co's are
robbing us, and the war is About Oil, I buy gas Very reluctantly, and
like if being robbed, if a mugger only got Some of the money you had
on you, you feel like you didn't get taken for That much, I try to
give them as little as possible. I usually only drive 2mi/day.
I smoke and smoke little filtered cigars that look like brown
cigarettes, 20 to a pack. I get them at a wholesaler, and with No
cigarette tax, they are costing me 1$/pk. Because the wholesaler is
only open M-F 9-4PM, and because of my injury, I don't function that
well in the daytime in traffic, I stock up. I never spent more than .
90/ pack for cigarettes, since when the name brands got that high, I
found a cheaper one at .60/. When they went up I found the little
cigars for that much. When they hit ,90/ I found the brand I smoke now
at .45/. I was buying 180 packs at a time, so I didn't have to make
the trip in the day that often, and they are only 1mi away. Now they
are up to 1$/, and I only buy 120 packs. As cheap as they are, it
still is a struggle to part with the money.
With my old car, if I fill up in NJ, I still run it down till the
needed stops moving, and then I reluctantly buy more. Because I ran
out SO many times when I was much worse, I carry a can of gas in the
trunk. I haven't run the Sube down to see the light, but put 5$ in
twice, and 10$ once, and 25 when in NJ. I thought about filling when
in NJ, but have been going over more often recently, and to break in
the Sube faster, I've taken some 100mi plus trips, to drive it in
different areas, on different type roads, to get familiar with the car
on them.
Everything is a learning and relearning experience for me. When
buying something I get jammed up if I feel I am spending 1$ more than
need be. It is a challenge to find or get the best price. Ebay was
driving me crazy, and making my heart race and head hurt when getting
close to the end of the auction. With the damage I have, I started to
worry about having a stroke or heart attack for a few $, so eased up,
and pick a price I can live with, and go with that, win or loose.
VF
yea, I know about partial fills and condensation. I used to work with
aircraft fuels in the air force. The fuels are filtered, and icing
inhibitors take care of the water. That's why dry gas isn't necessary
now, and fuel pumps don't have removable glass bowls to see the water
and dirt collecting in them.
VF
