crank pulley torque - wrong in books?
R
Remco
Hi all
Got the Impreza engine all back together and was just triple checking
what I have done - it will be going back in tomorrow if all goes well.
Just read a post that states that the crank pulley is supposed to be
tightened to over 100 ft/lb and that the manuals are all wrong. Is this
true?
Both my impreza manual say that it is supposed to be 69-76 ft/lb so I
tightened it to 73. Is that right? Does it require blue locktite? If
the manual is wrong, is it wrong elsewhere I need to know about?
tia
Remco
Edward said:
130 ft/lbs is the magic number for my 2.5L Forester 2000.
Thanks - looking at the engine manual for a 2.5, that is also
considerably higher. I'll retorque mine.
Wonder why these manuals are so consistently off..?
Hi Remco!
Hi all
true?
You will have noticed that only the last 10mm or so of the crank and
key actually engage the pulley. If it _does_ loosen in service, at the
very least it buggers up the end of the crank. I generally get the
bolt as tight as I can; probably in the 150ftlb range. I don't use
loctite, but it certainly won't hurt anything to add a dab.
If this seems excessive, think back to how much trouble it was to
loosen that sucker . . . that's where you want it.
Mmmmm, what else? Resist the temptation to over-tighten the exhaust
manifold nuts. I don't know what the book says, but these should only
be tight enough to compress the gasket a little, not crush it.
Probably around 10ftlb-ish. Also put some antisieze compound on the
studs; somewhere on down the road, someone will thank you for it.
Nothing else stands out in my memory; reasonable torque values
achieved with the hand tools that fit the fasteners should be fine.
"And the tears of it are wet" ;-)
(Mark Antony, from Shakespeare's Antony and Cleopatra; look it up if
you want a chuckle.)
Plan on going over everything after the new motor has been run a bit.
Just to put your mind at ease, don'cha know.
S said:
Hi Remco!
I was wondering about that - It looked the same when I took the crank
off (took pictures of everything) so figured that was normal.
Yup -- I used an old Radio Shack antenna pole to loosen it. :)
That's what I did. I've had suckers like that break on me on a
different car - not fun.
Antiseize compound is our friend :)
LOL! There's a reference I had forgotten about.
That's an excellent thought and will follow that advice.
Thanks!
Remco
Chris Dalton
