Continuation of 1996 Legacy Outback Electrical problem, more help!!
F
fly1747
Just an update, as you will remember the car suffered a voltage drop
when ever I pressed the brake pedal at ilde. Regardless of what
accessories were running, I got a voltage drop.
I changed the alternator for the heck of it. I still am getting the
volatage drop and dimming of what ever lights are on when press the
brake pedal. Battery is brande new and puts out correct voltage.
Here is what I have found. On the drivers side left strut housing in
the engine compartment, there are a few grounds that connect to the top
of it and one of those ground wires is broken. I am wandering if this
could be a problem?
Where are other grounds I could check.
Thanks for the boards help, lots of good info.
Any more suggestions? My knowledge of electrical work is poor.
Matt
