Automatic transmission noise. 2002 Subaru Impreza Sport
C
Chris Beatie
While stopped at stop lights in Drive there is a odd shuddering noise coming
from my transmission. You can't here this noise outside of the car, and
it's only when the car is in gear. I recently checked the fluid level on
the auto tranny and it appears to be a little high. Has anyone experienced
this same noise or know if a slighty overfull automatic tranny might make
funny noises?
Could be just the idle speed is at a certain resonance point. Try stepping
on the accelerator slightly (with your other foot on the brake pedal) to
raise the rpm by a hundred rpm or so, if the noise goes away, have a shop
check the idle speed and adjust it up or down if out of spec.
Ed B.
I have an older Legacy Outback with 94000 Miles. I noticed that the
trany is producing some vibration in similar conditions as you
described. If I put it in N the vibrations go down. Have you tried
that.? Maybe the idle speed is off. Well, just guessing,
Regards,
Dan
