all tires of same tread necessary??
C
catherine mason
is it true that on all wheel drive cars all 4 treads must be the same??
Can the front be of 1 tread and the back of another tread??
No, but the front should be the same, and the back should be the same.
Father Guido
I plan on living forever... so far, so good
With AWD they have to be the same
or you will screw up your AWD system
It is claimed that the circumference must be the same front to rear, but why
would the tread need to be the same?
Richard said:
As long as they are of the same circumference there's no problem.
Without any scientific evidence to back this up, I've never felt
comfortable with putting different varieties of tires on a car due to
their different driving characteristics. Nature seems to appreciate
symmetry.
please, please, please!!! use the same tires front and back on an AWD.
few years ago I had to put (actually, the insurance company) different
pairs front and back on a 1997 2.2 Sport Impreza MT. few thousands
miles after, the car started to make small sudden pulls with every
shift.... it spent more time at Subaru Service than anything else....
after several attempts without results, some guy at the garage noticed
the tire difference............
problem solved!!!
and just to be more energetic, the 4 tires were same brand, same size,
same specifications, _only_ different tread! Subaru didn't cover it,
and I didn't want to go back with the insurance company. but the
service did cover evreything else they tried ;-)
cheers,
MO
Subaru uses two types of AWD systems, one for the 4EAT and one for the 5MT.
With the 4EAT there is a hydraulic fluid shift within the transmission that
transfers power from front to rear and back. If you have different tires
on you may overheat the transmission as well as not get the benefits of AWD.
(If you are using the small spare, there is a place for a fuse to disable
the AWD or VDC so as to not harm the transmission with the doughnut)
With the 5MT you need to still use matching tires all around to get the
benefits of AWD but there is less likelihood of damaging the AWD system on
your vehicle.
Marc S
Natick Subaru Sales
(e-mail address removed)
Chris Dalton
