*** a/c compressor noise ***
F
fORCE=fED
Can some of you regulars speculate as to a noise my A/C compressor makes
everytime it kicks on.....it almost sounds like a bypass valve relieving
pressure. "pfffffft" !!!!!
I just took the car in for it's 30,000 mile service....I'm not sure if the
dealership mechanic checked the freon levels.... if they topped it off...is
it possible they mechanic overfilled it and the excess pressure will
eventually be expelled????
Anyone from Mastro Subaru, feel free to comment..... 'cause the car's coming
back !
fORCE fED
Does it just make the sound one time when you turn your dash switch to call
for AC, or does it repeatedly make the noise as you drive along?
It may be a vacuum leak under the dash coming from a hose to one of your
damper doors in the AC system.
The sound happens when I first turn on the A/C (compressor) and everytime
the compressor comes back on.....apparently it cycles on and off frequently
during normal operation......
But......after a week of ignoring the problem it seems to have corrected
itself....My explanation is that the excess pressure has slowly been
released over time and all is well now...
...I wish all problems were solved by denial.....
Thanks for the reply,
fORCE fED
____________________________________________________________________________
______
Some times the noise is due to a sticky expansion valve in the
evaporator inside the car.
I have heard them whistle too. Be thankful yours is not one of them... LOL
